Colouring the inside of engravings with Delrin
Hello everyone, I am working on a Delrin base plate project with letter engravings on the top. The material is white. Is there a procedure you follow to colour the inside of the engravings black, so the words stand out on the white background?
Apr 02
Feb 19
Feb 20
