Comparison of Nylon 12 (PA 12) SLS with PA6 GF30
Question about Nylon 12 (PA 12) glass fiber reinforced (SLS) – is the aforementioned method and material best comparable to the material PA6 GF30?
Solved by Nikolaus Mroncz
Hello Ramdesign,
the best alternative for PA6 GF30 would be in SLS PA12 GF.
VG
      Hello Ramdesign,
      VG
Surface Finish
Dec 17
