Dec 08
Dec 09
Gasket material for short-term hydrotest on carbon steel piping
Looking for advice on selecting a gasket material for temporary spool joints during a hydrotest on carbon steel piping in a refinery. The test medium will be demineralized water (low conductivity, no additives), and... read more
Dec 08
Acrylic or pc for outdoor enclosures
hi! For transparent cover for an outdoor sensor needs to stay clear, handle some impacts, and resist sunlight - would you go with acrylic or polycarbonate? Acrylic has better UV and scratch resistance, but... read more
Nov 26
Best flexible 3D printing material for vibration-damping motor mounts
Hi Everyone! We’re designing a vibration-damping mounting bracket (approx. 150×80×40 mm) for a small electric motor housing, and we’re considering 3D printing it in a flexible material. Given the operating environment includes oil exposure,... read more
Nov 27
