Designer Wanted
I want to work with a friend who has a millimetric design ability for a project I am currently working on.
Solved by Sinem Çiftçi
Hello Mr. Gökhan,
If you provide some details about the design or about your areas of expertise, it will be more appealing to designers. If we have a designer in our community with the appropriate expertise, they will think that the potential work is relevant to them and they will contact you.
Even if you can't get direct design service from Xometry, you can do price checks on xometry.com.tr throughout the design process and get design feedback.
Good luck with your project,
The Xometry Turkey Team
    • I want to work with a friend who has a millimetric design ability for a project I am currently working on.
      Hello Mr. Gökhan,
      Even if you can’t get direct design service from Xometry, you can do price checks on xometry.com.tr throughout the design process and get design feedback.
    • Hello Mr. Gökhan,
      I am experienced in 3D parametric CAD design and product development, I provide design services. How can I assist you? We can get in touch.
      Celalettin Toprak
      http://www.celalettintoprak.com
Designer Wanted
Mar 02
Dec 23
Dec 29
SLA wall thickness issue for microfluidic channels
Hi, I created a 3D design for a small microfluidic part using SLA (Clear Resin) with internal channels ~0.4 mm wide and wall thickness around 0.5 mm. The function relies on optical inspection through... read more
c
1.4k
