Gluing together SLS parts for larger builds?
Hey, community,
I’m working on a project that needs parts larger than what a regular SLS 3D printer can accommodate. My plan involves having smaller segments printed and then using adhesive to assemble them into the final, larger piece. Before I dive in, I’m seeking your expertise on a few points:
- Given that the parts won’t face heavy loads, is using adhesive to join SLS printed pieces a practical approach for achieving larger dimensions?
- What adhesives or surface preparation methods would you recommend for this kind of task?
- Could you share any challenges I should anticipate or tips to ensure the connections between the parts are as strong and durable as possible?
Looking forward to your advice and thank you for your help!
Apr 02
Feb 19
Feb 20
