hidrogene turbine
I want you to make me two hulls of about 20 cm radius and a 16 cm rotor for a turbine that will burn hydrogen with oxygen.
    • I want you to make me two hulls of about 20 cm radius and a 16 cm rotor for a turbine that will burn hydrogen with oxygen.
      Hi Sebastian,
      You can upload the 3D files of the two hulls on our platform, select all the specifications, and you should receive a quote instantly and be able to proceed to the production.
      On this link, please click on the blue button saying “Get a quote” https://xometry.eu/en-tr/
      If you have any difficulties, please let me know.
hidrogene turbine
Feb 19
Feb 20
s
629
Jan 23
Hello,I am writing because I am developing fingerboard wheels as a new product within my own brand. I professionally manufacture fingerboard decks and concrete obstacles, and now I am expanding my catalogue with cast... read more
