How to ensure color uniformity in plastic injection?
Hello everyone, I am currently working on a mass production project through plastic injection. And I wonder how I can guarantee the correct color for all the pieces, knowing they will be manufactured in several lots. Do you have experiences and advice to ensure that the chosen color is the same every time? The color in question is RAL 5012 light blue. Thank you in advance for your help!
Feb 20
