I Want to Be a Supplier
We want to produce and sell products using our 3D printer.
On the test piece you requested (part number: 281893), the filament you want us to use is PA-12.
However, we cannot procure this product. Due to the unavailability of the filament, we could carry out this print with various filaments (ABS – ASA – PETG) that we have on hand.
If you can share information about an alternative filament other than PA-12, we would be glad to print the test piece and send it to you.
    • We want to produce and sell products using our 3D printer.
    • Hello,First of all, we thank you for your cooperation. You have indicated that the PA-12 filament is not available. In this case, you can carry out the production with ABS filament. However, you also need to inform us via the Messenger on our platform that the production will be carried out with ABS. As this test process covers not only the production quality but also packaging, shipping, and billing, it is very important that all stages are carefully conducted. We also ask you to share the information about the production and shipping process through the system. Do not hesitate to contact us if you have any questions. Thank you.
Sourcing Cad Designer
electric motor
Nov 10
1.7k
6.0k
Jul 02
