Mechanical drawing
We need 1 friend with high design power who can do mechanical drawing. Those who are interested can call Istanbul Perpa Trade Center 05353159415
Solved by Dogushan Colak
Hello Nevzat Bey, If you provide more details about the design, it will be more attractive for the designers. If we have a designer with the appropriate expertise in our community, they will contact you thinking that the potential job is related to them. You can check prices on xometry.com.tr during the design process and receive design feedback. Good luck with your project, The Xometry Turkey Team
    • We need 1 friend with high design power who can do mechanical drawing. Those who are interested can call Istanbul Perpa Trade Center 05353159415
      Hello Nevzat Bey,
Mechanical drawing
Mar 10
Mar 02
Dec 23
Dec 29
