PA12 and chemical steam smoothing: Resistance to seawater?
Good day,
I have a small question: does chemically steam-smoothed PA12 (with SLS/MJF) hold up well in seawater conditions? I’m considering using it for parts that are frequently exposed to seawater conditions. I know that chemical steam smoothing improves water resistance, but I’m curious about how effective it is against the hardness of seawater. Any experiences or insights?
Solved by Nikolaus Mroncz
Hello Mr. Schmidt,
PA12 in itself is very chemically resistant. The chemical steam smoothing seals the pores and leads to higher resistance. I consider it suitable for use under seawater conditions.
      Good day,
      Hello Mr. Schmidt,
        Nikolaus Mroncz
        All clear, thank you very much!
Surface Finish
Dec 17
