Painting recommendations and compatibility for ready-made SLS parts
Hi everyone,
Are the existing SLS 3d printed parts suitable for painting, whether by spray-painting, hand painting, or other methods? Which paint types are recommended? are there any to avoid due to compatibility issues?
Solved by Nikolaus Mroncz
Dear,
SLS parts are good for painting.
You can also order spray painted parts directly at Xometry, what I also think, is the best option to achieve a constant result.
      Hi everyone,
      Dear,
Jan 30
Surface Finish
Dec 17
Dec 09
