s
Hello, I was wondering if there would be any issues in requesting the production of a print from a model purchased from a third party.
Thank you and keep up the good work!
    • s
    • Good morning dear user, does your question concern any copyright issues?
    • s
      Hello and thank you for the response.
      Exactly; protections, licenses and copyright.
    • This is a rather delicate matter. We can manufacture these products for you, but you will not be able to resell them to third parties. If you do, you would be committing a copyright infringement.
    • s
      Very clear, thank you.
      In the description of the file for sale, it is specified that resale is prohibited unless authorized by written consent.
      However, I would be interested in producing a full-sized print of a lion skull.
      The volumes are quite complex, I would need a high definition and smooth finish.
      Next month, I will send you a link to the 3D model for sale to give you a more precise idea and to advise me on the most suitable type of print and material.
      In the meantime, thank you for your availability, good work!
Feb 19
Feb 20
Hello,I am writing because I am developing fingerboard wheels as a new product within my own brand. I professionally manufacture fingerboard decks and concrete obstacles, and now I am expanding my catalogue with cast... read more
