Sheet metal forming?
d
Hello, can anyone tell me if sheet metal forming is a reliable process for the production of parts like this one? Not for the entire piece on the model, but only the central bar. I don’t know if forming can provide the necessary precision and structural integrity for our project. Maybe machining is more appropriate?
