FEA of a welded tow hitch
Hi! Need help on a welded tow hitch for an off-road vehicle using S355 steel tubing and 8 mm plates. It needs to handle a 3,500 kg towing load with off-axis forces. In ANSYS, I’m seeing high stress at the weld toes, which seems mesh-dependent. Would refining the mesh be enough, or should I use sub-modeling or another method to get more accurate results? Any insights from real-world validation would be helpful.
1. Product Photography:
2.1k
2.9k
2.8k
