Hi everyone, I have a new part I am looking to prototype. I am thinking of 3D printing out of Nylon 12. But there are features that require K7 hole tolerance. Do you think this is achievable by 3D printing? Or should I choose milling instead?
Solved by Nikolaus Mroncz
Hi Jari,
unfortunately we can't print fittings.
Better to choose CNC here.
BR
      Hi Jari,
      unfortunately we can’t print fittings.
      BR
1.4k
