Material for high temperature applications
Hello, I would like to make a piece that is intended to fit into an industrial equipment where the temperature can reach up to 220-240 degrees Celsius. I wonder what is the cheapest 3D printing option for this piece, capable of withstanding these high temperatures for an extended period. Thank you
Solved by Manon Bouriaud
Hello adrimeca,
There is not a wide choice of 3D printing materials that can withstand such temperatures. Do you want to make a piece in plastic or metal? Here are some material suggestions that might work:
  • Plastics
    • ULTEM 1010 is probably the best option for plastic materials, with a temperature resistance up to 216°C. It is compatible with FDM (Fused Deposition Modelling) 3D printing technology
    • CE 221 has an even higher resistance (over 220°C) but Carbon's DLS technology is still expensive, especially compared to FDM
  • Metals - I'd recommend the following materials for 3D metal printing (DMLS)
    • Aluminium AlSi10Mg
    • Stainless steel 316L
    • Inconel 718
I would say that aluminium AlSi10Mg remains the most viable option considering your requirements. I hope this answer will be useful to you!
    • a
    • Senior Content Manager
      Hello adrimeca,
      • Plastics
        • CE 221 has an even higher resistance (over 220°C) but Carbon’s DLS technology is still expensive, especially compared to FDM
      • Metals – I’d recommend the following materials for 3D metal printing (DMLS)
        • Inconel 718
Surface Finish
Dec 17
