Need recommendations for a solid aluminum alloy
Hello, I am designing a bottle opener and want to use aluminum. I need an alloy that is strong enough. The opener will not be very thin, I am thinking of 3-4 mm at the thinnest points, so it should not bend, but I still want to be sure here. Does anyone have a recommendation?
May 05
