Slit dimensions for CNC machined parts
Hello everyone, I am working on a project that requires the addition of some slits to aluminium parts using CNC machining. What is the thinnest slit width that I can design in my CAD file?
Dec 23
Hi, I have two 400 mm cubical enclosures from 20Ă—20 mm aluminum profiles with glass on all sides except one. I need to connect them into a single temperature-controlled unit and keep the joint... read more
Dec 29
