Good afternoon,Does Xometry perform welding work such as sealing the folds of a box-shaped design?Can Xometry weld a nut, for example, an aluminum DIN934, onto an aluminum sheet?Regards read more
May 22
May 22
Choosing Bending Methods and Sheet Metal Development in Sheet Metal Bends
I want to design and manufacture a bent sheet metal part in the most accurate way possible. Once the part's design is completed, I flatten the sheet, obtain the dxf, and cut it using... read more
May 22
