Which AI tools are helping your engineering work?
Hi, we’ve started exploring how AI fits into everyday engineering workflows and want to hear what’s working for others. Are there any AI tools or plugins you’re using (or experimenting with) for design, modeling... read more
Nov 18
Transferring assembly cuts to part files in SolidWorks
I'm designing a clamping fixture for a CNC-milled aluminum part on Solidworks, where a set of pins and slots needs to precisely align across multiple plates. I initially created the cut features at the... read more
4.6k
Jul 02
Text-to-CAD tools for modeling enclosures
Has anyone tested text-to-CAD tools for quick concept modeling of enclosures? I'm designing a small plastic enclosure for a PCB-based sensor module (around 60x40x20 mm) and was wondering if any of the new text-to-CAD... read more
4.4k
Jul 03
Simulating shear and bending on a welded tow hook bracket
I'm designing a welded tow hook bracket for a lightweight off-road trailer (max gross weight 850 kg), made from 8 mm thick mild steel plates (S355), joined with full-penetration fillet welds. I’m running a... read more
2.3k
