Aluminum 6061 T6 sheet with 1.0mm thickness
Hello, everyone  what is the information about the dielectric coefficient, impact resistance, tensile resistance or strength of the material “1.0mm thick aluminum 6061 T6 sheet metal”? I can also get the data sheet
Solved by Dogushan Colak
Hello, due to its metal composition, 6061-T6 material does not have a dielectric structure. However, 6061-T6 materials exhibit an average impact resistance of around 7-8 J. Their tensile strengths can vary between 270-300 MPa.
    • Hello, everyone  what is the information about the dielectric coefficient, impact resistance, tensile resistance or strength of the material “1.0mm thick aluminum 6061 T6 sheet metal”? I can also get the data sheet
May 05
