Hi everyone, I’m working with DMLS (AlSi10Mg) and looking for advice on post-processing. What finishing methods do you recommend to achieve a smooth (non-grainy) surface, especially for functional parts? Also, what’s the best approach to make parts fully leak-proof—would vacuum impregnation be sufficient, or do you suggest additional coatings (e.g., anodizing or epoxy)? Appreciate any insights or real-world experience.
Surface Finish
Dec 17
Dec 09
