How data quality impacts 3D printing resolution
Hey everyone! I’m having some trouble with weird surface quality when 3D printing my models. The resolution of my prints seems to be awful, with surfaces looking faceted and curves that look lumpy. Can anyone explain what I might be doing wrong?
Nov 18
5.2k
Jul 02
4.6k
Jul 03
2.4k
