Looking for CAD Freelancers or Design Offices for a Technical Project
10
Hello Community! Does anyone know a good freelancer or a small design office in Germany that can create a CAD model from an old technical drawing? I also need to make some adjustments to the design. I’m looking for someone who can always provide support when I need help with CAD or technical drawings.
Thanks,
Bastian
      Thanks,
      Bastian
    • Admin
      This is a good topic – if someone in the community wants to briefly introduce their CAD drawing services here, please do so – we welcome this type of professional cooperation among our community members. You can also provide your direct contact details or a link to your website in this thread.
      Hello Sebastian,
      my name is Matthias Fenski and I have been running a small design office since 2020.
      I have been working in machine and plant construction for well over 20 years and would be very happy to help you here.
      Among other things, I offer the following services:
      – Creation of CAD models
      – Drawing derivations
      – Creation of neutral formats (STEP, IGES, PDF)
      – Machine and plant designs
      Here is the link to my homepage:
      https://mf-konstruktion.de/
      My contact details are:
      Mobile: +49 174/9059979
      Mail: matthias.fenski@mf-konstruktion.de
      I would be very pleased to be contacted.
      Regards, Matthias
        Matthias Fenski
        Thank you very much! I have already found help for my project, but I will keep you in mind for future projects
      • l
        Matthias Fenski
        Hi! Do you also make standard pieces for packaging as a soap dispenser pump 14/200, a roll on base DIN18 and a dropper for essential oils DIN18? I would like to make them with stainless steel, in order to reuse them and reducing toxic exposure. Is it a possible project?
    • i
      Hello Everyone,
      If anyone needs help with constructions, feel free to contact me.
      Christian Brauner
      brauner.ahlen@web.de
      I work with Siemens NX. I also have the ability to convert and edit the most common CAD data. (Creo, Catia, Solidworks, Rhino, Inventor)
      Regards, Christian.
    • N
      Hello, my name is Nico and I am a passionate construction engineer from Germany with over 10 years of experience, specializing in the use of SolidWorks. I offer a wide range of design services, providing customized solutions for construction activities to you and my long-term customers. My long-standing experience and expertise as an engineer give you sustainable competitive advantages.
      Key areas of expertise:
      – 3D modeling with SolidWorks
      – Creation of technical drawings
      – Special machine construction
      – Component development
      – Automation including deep pneumatic knowledge
      I look forward to supporting you in your next project. Feel free to contact me for further information and possibilities for cooperation.
      Here are my contact details. Here you can also see my previous references:
      mail@metzler-engineering.de
      https://www.metzler-engineering.de/
      Greetings, Nico
    • Yes I can do that. I am mechanical engineer and I use to work in cement factory for 6 years in investment department and I can easily do that
    • Hello, I have experience with an engineering office, specializing in mechanical engineering in the Automotive, Aeronautics fields with
      eight years of experience in CNC programming on 3, 4 and 5 axes, mainly in the aeronautical industry. I am particularly enthusiastic about the idea of contributing to your projects as a Methods Technician specialized in CFAO under Catia V5 and in simulation on Vericut 9.4
    • Hello Sebastian and everyone in the Xometry community,
      My name is Patrick Hübner and I also run a design office and have worked with a lot of customers using Xometry since 2019. Our specialty is providing and correcting CAD designs quickly. All of our engineers are based in Europe. Our services include: – CAD models, – production designs, – materials and tools consulting (especially for sheet metal and 3d printing), – robotics designs and production.
      Our website is here: https://www.holydraft.de
      You can book a meeting with me directly through the website calendar or just contact me directly at this number or email:
      Mobile: +49 176 32602154
      Email: patrick@holydraft.com
      Best, Patrick
      Sebastian
      Hello Sebastian,
      No problem.
      I’m very happy to help anytime.
      Regards, Matthias
electric motor
Nov 18
5.0k
Jul 02
e
4.5k
Jul 03
2.4k
