Moulding of a Concave Disk
Hello everyone, I want to make a disk of 203 mm in diameter, 25 mm in height with a concave curvature of 3.22 mm.
Will this precision be respected knowing that I am not a professional but an individual?
Scanning and Printing
Jul 17
2.7k
1.6k
