Recommended wall-thickness for FDM
I
8
Hello! what could be the optimal wall thickness for FDM 3d printing large-scale parts, considering material strength and without compromising structural integrity?
Solved by Nikolaus Mroncz
Hello, there is no general answer here, so better to evaluate the concrete part.
We recommend a minimum wall thickness of 1-2mm for unsupported walls in FDM, but this depends also to the overall design.
BR
    • I
      BR
      • I
        Nikolaus Mroncz
        Hi Nikolaus, thank you for your reply! How is it in other 3D printing technologies? Do you have, probably a comparison about the different technologies and their wall thicknesses?
      Hey, here you have an overview of the 3D technologies we offer and their design limitations:
      Infographic: Design Rules for 3D Printing
      • I
        Nikolaus Mroncz
        thank you! that’s helpful
Scanning and Printing
Jul 17
2.6k
1.5k
