Steel Advice
Hello
I would like to request a quote for cold cutting tools (no temperature problems). I usually work with high-speed steels, for their hardness and the relative ease of re-sharpening, but none is offered in the list of Xiometry. Are there alternatives?
Thanks in advance
Matthieu C.
Surface Finish
Dec 17
