Surface Finish
I am looking to have some Aluminium samples made…………without adding extra post process operations what is the best surface finish possible (um) ?
    • a
    • j
      Hi Alan,
      Standard Ra values in Xometry are:
Surface Finish
Dec 17
Dec 09
