en – EU
    • P
Scanning and Printing
Good day, I have a plastic component that I would like you to scan and reproduce in metallic material. Could you tell me if I can send you the plastic component for evaluation? Thank... read more
Jul 17
Welding
Good afternoon,Does Xometry perform welding work such as sealing the folds of a box-shaped design?Can Xometry weld a nut, for example an aluminum DIN934, onto an aluminum sheet?Best regards read more
Selection of Bending Method in Sheet Metal Bends and Sheet Metal Unfolding
I want to design and manufacture a bent sheet metal part in the most accurate way possible. Once the design of the part is finished, I flatten the sheet, get a DXF file, and... read more
H7/g6 fit – is it too tight for manual assembly?
Hi, I’m using a limits-and-fits guide to spec a bearing housing. I’m looking at an H7/g6 fit for a sliding location, but this is a field-repaired unit. If I go that tight, is some... read more
1.4k
