Design tips for living hinges for plastics
Hey. I’m working on an insecticide sprayer, using a living hinge battery compartment. I’d like thoughts on design and durability issues. I know material selection is a big deal – it needs to be tough, flexible and durable. What about Polypropylene? It’s supposed to have a good fatigue resistance and it’s not expensive.
1. Product Photography:
1.4k
2.0k
Mar 16
3.2k
