Effect of microblasting on the properties of a piece
t
Hello everyone, can the microblasting process modify the dimensions or affect the mechanical properties of a piece? If anyone has information or experiences to share, I am all ears. Thank you in advance for your help !
Surface Finish
Dec 17
