Effect of zinc flake coating thickness on bolt performance
In an automotive subframe project using M12 class 10.9 bolts, exposed to salt spray and vibration, I’m looking into zinc flake coatings for corrosion protection. Curious if doubling the coating thickness—from 8 µm to 16 µm—actually improves durability in the field, or if benefits plateau and sealing topcoats make a bigger difference. Has anyone seen clear data or long-term results on this?
Surface Finish
Dec 17
