How to ensure solid models for load-bearing designs
Hi everyone, I’m designing a structural component for a load-bearing assembly and need to ensure the CAD model is fully solid to avoid issues during manufacturing. What are the best practices for verifying that all points, curves, and vertices are properly connected and that the geometry consists only of closed shapes? Additionally, are there tools or methods to generate accurate technical illustrations from such a model to clearly communicate the design intent?
Sourcing Cad Designer
Nov 10
1.9k
5.6k
Jul 02
