I Want to Be a Supplier
We want to produce and sell products using our 3D printer.
On the test piece you requested (part number: 281893), the filament you want us to use is PA-12.
However, we cannot procure this product. Due to the unavailability of the filament, we could carry out this print with various filaments (ABS – ASA – PETG) that we have on hand.
If you can share information about an alternative filament other than PA-12, we would be glad to print the test piece and send it to you.
Sourcing Cad Designer
Nov 10
1.9k
5.6k
Jul 02
