Apr 02
Feb 19
Feb 20
However, remember that this graph only shows the change in unit cost depending on the quantity. If you notice, the intersection point is somewhere between 100-1000 units. At Xometry, we can recommend the most suitable production method for you according to the part design, delivery time, material properties, and project requirements. Important Notes:
