Materials to Avoid When Laser Cutting
Hi, I have to do a lot of laser cuts for custom cases and parts. I know that some materials are bad for laser cutting, but I’m not sure which ones I should avoid. Does anyone have a suggestion on which materials I should stay away from? And tips for dealing with delicate materials like PVC or polycarbonate would also be very helpful – thanks a lot in advance!
Scanning and Printing
Jul 17
1.6k
