OD and ID vs OD and Wall Thickness - which is the best method of dimensioning?
Hello All,
I am designing a conical-shaped plastic bushing and am confused if specifying the OD and the wall thickness is better for controlling the manufacturing process, or OD and ID separately, with their tolerance ranges individually specified?
Scanning and Printing
Jul 17
1.5k
