Seeking advice: best CAD file format for multi-colored 3D printed toys?
What type of CAD file should I use for 3D printing if I want to create multi-colored small sculptures (toys)? I’m unsure if STL is the best format for this purpose. So far, I’ve primarily worked with STL files and would appreciate advice from the community to find the best alternative.
Nov 10
3.8k
Jul 02
4.7k
Jul 03
