Has anyone tested text-to-CAD tools for quick concept modeling of enclosures? I’m designing a small plastic enclosure for a PCB-based sensor module (around 60x40x20 mm) and was wondering if any of the new text-to-CAD AI tools could help speed up early-stage conception—just basic geometry, mounting bosses, snap-fit features, and some ventilation slots. I don’t expect full manufacturable parts, but something good enough to clean up in Fusion or SolidWorks.
Nov 10
4.0k
Jul 02
2.1k
