Content Manager
Hi, we’ve started exploring how AI fits into everyday engineering workflows and want to hear what’s working for others. Are there any AI tools or plugins you’re using (or experimenting with) for design, modeling or CAD automation? What’s actually useful for you?
As part of this exploration, we’ve put together a few pieces looking at how AI is being applied in engineering today:
  • Automating Macro Creation with AI – Interview with Mecagent’s CEO — on integrating AI directly into CAD to automate repetitive tasks:
  • We Tested 7 Text-to-CAD Tools – Are They Actually Useful for Engineers? — test of current AI-driven CAD generators and how well they handle practical mechanical design prompts.
What tools or approaches are you finding most useful in your own workflow?
    • Content Manager
electric motor
3.8k
Jul 02
e
4.6k
Jul 03
2.0k
