Hi,
Working on a compact gearbox for a robotic arm and need advice on the best gear setup. The arm sees intermittent loads, max torque at the output is 15 Nm, and I need about a 25:1 reduction. Space is tight, so I’m debating between a planetary system or a helical-spur combo. Priority is low backlash, even load distribution, and durability while keeping it manufacturable.
Would a planetary setup handle varying loads better, or is a helical-spur mix a smarter choice for efficiency and longevity?
