CAD software for CNC machining
I need to design intended to be machined with CNC. Could you recommend me a CAD software that will be appropriate to define my specification and geometry correctly?
Solved by Attila Szucs
Software choices like PTC Creo, SolidWorks, Autodesk Inventor, or Fusion 360 are all excellent options. Each provides strong tools for accurately defining specifications. Integration with CAM software, ease of data transfer, and support matter too. Factor these alongside budget and project needs for a decision.
    • For my last project, I found SolidWorks to be incredibly helpful. It’s accurate, and its CAM features streamline the whole process.
electric motor
Nov 18
3.2k
Jul 02
e
3.5k
Jul 03
1.8k
