Nov 18
3.6k
Jul 02
3.8k
Jul 03
1.9k
Solidworks or Inventor for sheet metal design?
Hey, I need to create a small sheet metal enclosure for a power supply unit—mostly bent parts in 1.5 mm steel, with tabs, cutouts, and a few fastener points. I’m new to CAD and... read more
2.6k
Jun 24
