E-Books & Guides
Create Topic
Ergonomic Hand Tool Handle: Overmolding or Something Else?
Hello everyone, I am in the early stages of developing a new hand tool (wire cutter). The tool needs an ergonomic handle that provides a good grip and comfort even during prolonged use. I am considering various materials, including plastics and metals, and am thinking about overmolding the handle with an elastomer to ensure additional comfort and slip-resistant properties. However, I have almost no experience with overmolding. Can anyone help me or provide insight into potential problems if I decide for overmolding? Or if I decide for a pure plastic part, could SLS/MJF PA12 be suitable for such a handle? Any advice on materials, manufacturing processes, or design tips would be very helpful! Thank you very much! Max
Solved by Nikolaus Mroncz
Hi Max, thanks for your question. We can print in Polyjet hard - soft. The connection here is not always optimal. This would be the solution from one print. I don't know if you could print in 2 parts, i.e. the handle made of soft material such as TPU over the second, hard one? PA 12 in SLS/Mjf I think is always a good choice and certainly provides a first statement about ergonomics.
VG
Niko
      Hi Max, thanks for your question. We can print in Polyjet hard – soft. The connection here is not always optimal. This would be the solution from one print. I don’t know if you could print in 2 parts, i.e. the handle made of soft material such as TPU over the second, hard one? PA 12 in SLS/Mjf I think is always a good choice and certainly provides a first statement about ergonomics.
      VG
      Niko
        Nikolaus Mroncz
        Hello Niko,
        Thank you very much for the information. Would Polyjet or the TPU solution be durable enough for a final product? I would need some prototypes for testing, but for the final product I thought it would make sense to work with hard plastics or rubber/elastomer for durability reasons.
        Do you know if overmoulding is a cost-effective solution?
        Otherwise, I think it’s possible to have two components for the handle.
        Thanks,
        Max
      Maximilian Lang
      Hey Max,
      which process is best for you also strongly depends on the design and quantity of your parts.
      Unfortunately, I can only recommend the Polyjet for prototype manufacturing, as hard and soft components do not have the best adhesion and are only short-term when used. I would try the TPU version.
      Overmolding would be an option, one would need to compare accordingly, which is more economical.
      Best regards
      Niko
      Nikolaus Mroncz
      All clear, thank you!
