E-Books & Guides
Create Topic
FDM finish options to smoothen the surface
Hi everyone, I’m planning to 3D print a part using FDM technology, but I’m concerned about the visible layer lines that typically appear on the surface. Does anyone have experience with effective techniques to achieve a smoother finish, such as sanding, chemical vapor polishing, or similar methods?
Solved by Nikolaus Mroncz
Dear Heinrich, vapor smoothing for FDM 3D prints is indeed good for smoothing out layer lines. You may just want to keep in mind that it will also affect the dimensional accuracy of the part quite a bit, because the process dissolves the outer shell of your print. There are various grades of vapor smoothing, and in the highest grade, the process will dissolve details and sharp edges. If you need a preliminary finish to smoothen the surface before painting for instance, then sanding with grit sandpaper (150, 220, 400) is an option. Please note that it is not suitable for intricate surfaces and small details. And finally, you can also apply an epoxy coating – it is suitable for all FDM thermoplastics. It smooths out any remaining imperfections and also adds a layer of resin to the printed part that fills the gaps.
    • H
    • m
      Hello Heinrich, chemical vapor smoothing is a solid choice—it involves exposing the print to a solvent vapor that lightly melts the surface, smoothing out those layer lines and boosting the look. This technique works really well for ABS and certain types of PLA.
    • H
      Thanks everyone for the detailed advice! Since I’m looking for a more robust finish, then epoxy coating sounds like a good option.
May 05
2.4k
