How to improve paint adhesion to plastic?
Hey guys! I’m having issues with paint adhering properly. I’m trying to improve the cosmetics on some moldings of a waterproof portable speaker housing molded in ABS. The paint peels off easily after drying. Can anyone suggest effective methods or techniques to enhance paint adhesion to plastic surfaces? Any specific primers or surface treatments that work well? Thanks!
Sep 09
Title: How to build a smartphone from scratch (parts & assembly) Description: Hello, I want to build a smartphone from scratch as a learning project. Can you please provide: – A full list of required components (mainboard, display, battery, cameras, etc.) – Recommended models or compatible parts – Estimated prices for each part – Step-by-step instructions on how to assemble them I am a beginner but I have basic experience with phone repair. Thank you!
Title: How to build a smartphone from scratch (parts & assembly)Description:Hello, I want to build a smartphone from scratch as a learning project.Can you please provide:- A full list of required components (mainboard, display,... read more
May 05
2.3k
