E-Books & Guides
Create Topic
hi, designing a snap-fit enclosure for a small handheld sensor (approx. 60 x 40 x 20 mm), and I need to add structural ribs to the inner shell. The issue is the inner surface is slightly curved to accommodate an ergonomic grip, so the rib’s base isn’t flat. In Fusion 360, projecting the rib sketch onto the curved surface results in weird geometry when extruding, especially at the blend between the rib and wall. Is there a clean way to model ribs on a curved surface that still ensures proper draft for injection molding?
    • m
      You’re in luck – there’s been an update to the Rib command in Fusion 360, so that this now intelligently solves for connections with curved surfaces. Make sure you’re running the latest version of Fusion so that you have this update.
      Yup, exactly this! The Rib command is really cool, you can adjust all sorts of dimensions of the rib. Even when shifting it around on a curved surface, it fills in the material so that there are no gaps.
      I do know that the direction of the rib can be switched (so if the rib material is “outwards”, that will create really weird geometry), and I did also see one person struggling to use Rib because their two surfaces were two different bodies rather than combined as one body – but that doesn’t seem to be your issue here.
      It’s really not that hard – the Rib tool does this no problem. If you’re struggling to get it to work, you need to watch some Youtube instruction vids to be sure you’re using it right.
Sourcing Cad Designer
electric motor
Nov 10
1.7k
6.0k
Jul 02
