en – TR
Türkiye Türkiye
United Kingdom United Kingdom
Global Global
Hi,  I’m prototyping a small bracket for holding a plastic cover in place—roughly 60 × 30 × 10 mm, with two hooks and two screw holes (M3) on the top side. I printed it in PLA with 20% infill and a 2 mm wall, but one of the hooks cracked under moderate flexing during assembly. I’m trying to find the right balance between strength and cost—do you think increasing the wall thickness or switching to a higher infill density would be more effective to reinforce the hooks without overbuilding the rest?
    • G
I’m working on a small injection-molded housing for an automotive sensor, using PA6 GF30. There are two snap-fit arms inside (cantilever type), about 2 mm-thick walls. I’m not sure where to place the ejector... read more
hello, I'm designing a part with an FDM 3D printed hole to hold a 6mm wooden dowel, but I’m unsure about the actual fit due to print tolerances and material shrinkage. The hole is... read more
b
0.4mm text in PLA
