Title: How to build a smartphone from scratch (parts & assembly) Description: Hello, I want to build a smartphone from scratch as a learning project. Can you please provide: – A full list of required components (mainboard, display, battery, cameras, etc.) – Recommended models or compatible parts – Estimated prices for each part – Step-by-step instructions on how to assemble them I am a beginner but I have basic experience with phone repair. Thank you!
Title: How to build a smartphone from scratch (parts & assembly)Description:Hello, I want to build a smartphone from scratch as a learning project.Can you please provide:- A full list of required components (mainboard, display,... read more
May 05
2.4k
