en – TR
Europe Europe
Türkiye Türkiye
United Kingdom United Kingdom
Global Global
Good afternoon,
Does Xometry perform welding work such as sealing the folds of a box-shaped design?
Can Xometry weld a nut, for example, an aluminum DIN934 onto an aluminum sheet?
Best regards
    • j
      Good afternoon,
      Best regards
Good afternoon,Does Xometry perform welding work such as sealing the folds of a box-shaped design?Can Xometry weld a nut, for example, an aluminum DIN934, onto an aluminum sheet?Regards read more
May 22
May 22
